Major Disc Brakes
icom102
Major Disc Brakes
Post by icom102 »
How many brake discs go on a major with disc brakes?
super6954
Post by super6954 »
Hi there are 4 brake discs on a super major 2 on each side. if you are going to re line old discs you need 8 linings as there are 2 linings on each disc.
icom102
Post by icom102 »
So why would mine have jsut one disc on each side
mines like this
http://www.agrilineproducts.com/techdia ... lref9.html
it shows jsut one disc is this not correct ?
super6954
Post by super6954 »
Hi I just looked at the picture and something is wrong there. Every fordson super major i have ever owned or worked on had 2 discs in each brake side. I have 3 at the moment .
Could I just ask have you taken it apart and looked or just going by the parts picture? If you have and only found one disc Please remember some Farmers are resourcefull at saving money and it may not have been fixed properly at some point in its life.. working for farmers fixing tractors I should know nothing Suprises me any more.
That System needs the 2 discs to operate correctly as the discs are pressed out by the expander in the middle against 4 surfaces that do not rotate with the discs.
with only one disc it will probably make funny grinding sounds and be impossible to get the adjustment correct with out messing up all the expander springs!
That drawing does not show the complete brake. There are two discs, one either side of the actuator, otherwise there is a big space and the actutor won't touch the remaining disc.
I would suspect someone had sticking brakes, a common problem with all tractors fitted with this system and to remove a disc cured it. :shock:
icom102
Post by icom102 »
Hi no my father removed the parts so i dont actually know what was supposed to be there if there was 1 or two discs
northermajor
Post by northermajor »
id buy compleat lined disks its very hard to flaten the rivets without cracking the lineing as you do it :(
icom102
Post by icom102 »
Well brakes on today they seem to be working but cant test them correctly till i get it going there seems to be a brave bit of play between the foot pedal and the brake cross bar but i guess this cant be sorted
