Hello All, What a great site you have built here! Very informative.
I recently bought my first tractor, a Fordson Power Major or New Major mark lll? I have looked at the serial number translator page and still have questions. On the 4 cylinder diesel head it is stamped 1503462, and on the small plate on the firewall by the battery it says 1473672. Can anyone help me with this? Thanks in advance. Fordman
First Tractor
Your engine has most likely been swapped out for a newer unit... welcome to the board, most likely Brian will answer this question more thoroughly than I do but on the other hand, he's among the gods of Fordson and I'm a simple plebian
First tractor
Thank you Foxen! That was a very fast reply. I should use the 1473672 to tell what tractor I have then right? So then I suppose I own a 1473672: May 1958
New Fordson Major Mark II? is this a Power Major?
Welcome Fordman. I believe you are from my side of the world. With this site I have been able to get my Power Major up and running. The # on your engine indicates 1959. I have a 1959 Power Major, look at some of the pictures I have put on here and see if it looks like yours. I also have a 1957 Major I have for parts, some pictures of it are also on here. Are your gauges on top of your fuel tank or down under the fuel tank where the shifter is located? Pictures will help and as Foxen says Brian is one of the best and can help you.
Good luck.
Good luck.
Gman: 1959 Power Major
Hello Gman! I am only about a thousand miles from you! A short distance compared to most of the users I have seen on this forum. My tractor is in great shape and runs real good, it has fresh blue paint and came with a scraper and a loader that I am trying to figure out how to put on. The gauges are not on the tank, they are down below. Is a New Major Mark ll the same as a Power Major? I dont know much about these yet. I will post pictures of it later today. The Loader is a Davis. Model 102
A New Major Mark II is the predecessor to the Power Major...Fordman wrote:Hello Gman! I am only about a thousand miles from you! A short distance compared to most of the users I have seen on this forum. My tractor is in great shape and runs real good, it has fresh blue paint and came with a scraper and a loader that I am trying to figure out how to put on. The gauges are not on the tank, they are down below. Is a New Major Mark ll the same as a Power Major? I dont know much about these yet. I will post pictures of it later today. The Loader is a Davis. Model 102
The power and super majors are distinguishable by the gauges on top of the fuel tank, and the super major is distinguishable from the power major by it's different hydraulics and it's disc brakes... essentially
Hi again, take a look on page 2 on my post "please look and advice". This is a 1957 Major I bought for parts, it should look a lot like yours, well except mine is in parts. Click on one of the pictures and it will take you to imageshack, this is a good site to use for your pictures. I believe you can see all my pictures on there if you go to that site from here. Also another good site is the New Holland site and also try www.messicks.com. You can pull parts list with pictures of parts, you can also print them out.
