The rear mudguards were distorted through the tractor tipping over, and rusted out. Stormont bought the original style mud guards off Ford, which came in 2 pieces, the tops seperate to the sides. They cut them down to reduce the height.
The rear rims are 28 inch diameter, but the lugs (to fit to the centres) are longer than normal Fordson versions. The rims were badly pitted, and had to have 5 coats of filler-primer to fill in the indentations.
David
