During the re-assembly I decided not to fit the starting handle shaft that goes through the tombstone - I had banged my leg too many times walking past it
Also the radiator shutters were rusted out, and I could not find a decent set so these were omitted too.
Note the front axle and the wheel hub. The steering drag link was badly worn, its also shorter length than normal Major so one was built up from several s/h parts.
David
