Super major rear crank seal
liam
Post by liam »
I have a super major that is leaking at the rear crank seal and I hope to replace it in the next few days.
My question is does the new modern rope seals have to be soaked in oil first before fitting?
When I do fit it, how much of the seal do I leave protruding before assembly.
Thanks in advance.
I would oil it well rather than soak the modern ones. You need to leave about 2mm on each end.
liam
Post by liam »
Thanks for your help Brian .Will hopefully make a start at the weekend .
Supermanuel
Post by Supermanuel »
To change the clutch shaft oil seal at gearbox end is also a good idea.
New Performance Super Major Manuel 08D970466
