FSM smoke and no fire.
Posted: Sat Jul 19, 2008 3:15 am
				Hello again,
I am having trouble figuring out the problem with my other Super major.
Here is a brief history;
When I bought it, it would run, after a fashion, but with a terrible amount of white smoke.
Very bad to start.
Checked timing.
lines on injector pump and drive were out about nearly 1/4" when the mark was on 23 degrees BTDC.
Aligned marks on pump and drive.
Wouldn't go at all!
Had injectors serviced. No better.
Took off valve cover. 5 bent push-rods. (Owner had been starting it with the decompression lever)
while at it, wound up putting in new main and rod bearings, new piston rings, grinding in the valves.
and of course, some straight push-rods.
Set valve clearance.
Just got it back together.
Bled system.
Smoke, No firing though.
Re-checked timing. Dead on.
Beginning to wonder. This tractor had been apart before.
Is there a chance that someone had the cam out, and put it back without aligning the marks, and that is why it ran when "out of timing" and won't run when it is "timed"
I know a faulty injection pump could make it smoke, but it drove home a few miles running not too bad, considering.
I had figured the bent pushrods and worn rings were causing the problem.
Now, I dinna ken!
If anyone (Brian?) has a crystal ball, and could fill me in on what;s wrong, that would be marvelous!!
Thank you for your time,
Richard.
Very bad to start.
Checked timing.
Wouldn't go at all!
Bled system.
Now, I dinna ken!
Richard.
