Gearbox Oil Change
Posted: Tue Jun 14, 2011 6:32 pm
by icom102
Hi im going to change the oil in my Super major gearbox is there a filter in the box? and how much oil do i need i take it its just ordnary gear oil?
Re: Gearbox Oil Change
Posted: Tue Jun 14, 2011 7:26 pm
by Gman
Check Brian's oil spec. posts at top of this forum for correct oil. I have a Power Major and there are two drain plugs, one for trans. and one for rear end. You'll need to be ready for a lot of oil that will drain out. There is a filter in rear end.
Posted: Tue Jun 14, 2011 8:28 pm
by JC
The front gear box holds 20.43 liters and the rear end holds 41 liters. I doesn't use gear oil, check Brian's oil specs., like Gman said.
Posted: Tue Jun 14, 2011 11:38 pm
by icom102
Ok so theres no filter for the gearbox?
Posted: Wed Jun 15, 2011 2:09 am
by JC
No filter in the front transmission, but there's a hydraulic filter in the rear end. You will see a round cover on the bottom of the case with the drain plug in the middle of it. The filter is under (above) that.
Posted: Wed Jun 15, 2011 6:08 pm
by icom102
cheers
