Hi all I've a little problem
nathanwhittaker
Post by nathanwhittaker »
Hi all I've got water going into the sump. At first I thought it could be a liner but now I've heard the block rots away at the bottom of the liner. What is the best way of checking too see which liner is at fault Cheers
Re: Hi all I've a little problem
Post by Dandy Dave »
Pull the pan and see which is dripping coolant. With that said, chances are that the liner seals are all on there way to leaking. If you find a tear down is neccesary, You are better to replace them all at the same time. There is a good thread on here somewhere on repairing the block if yours is rusted where the seals seat. Could also be another problem, a Crack somewhere, a bad head gasket, a cavitated liner. Dandy Dave!
