I found this, your unit is a Bosch. The last Bosch in the list.
http://www.woodauto.com/Unit.aspx?Man=B ... 0120489287
The Delcos can be had for around $30 US, and come in 4 different positions to make connections easier. The pulley is easily changed to a wide pulley to fit the Fordson fan belt. It is best to go to a rebuild shop if you have one local. If you perfer to keep the Bosch, You should beable to get a suitible replacment at your local Auto parts supplier. I'm not sure how that unit is wired without researching it. The few Bosch units I have run into over here have had an electronic regulator that is separate from the alternator. They should also take the old unit as a rebuildable core.
Fordson Major Tractors were originally positive ground/earth. With changing it, it would reverse the polarity to negetive Ground/ Earth, as all modern alternators are this way, unless changed by a rebuilder to a 6 volt positive ground, or such, for a special application like putting an alternator on an old car from the 1930's. or 40's. with 6 volt positive ground. Or, a Ford 9N,2N,8N, tractor that the owner wants to keep it 6 volt. Probably to much infomation. But better too much, than not enough and end up cooking something from the start.
Even putting the cables on the wrong way to jump a battery could burn out the electronic components. Dandy Dave!
