Im getting ready to wire in my rear lights and side lights on my super major.
Now....the colour wires on the rear lamps don't match anything on the wiring diagra
? I presume the two wires from the rear lamps are one for power in and the other to the side lamps?
On the main harness there is just two spare wires which I've not used so again presume these are for the lights as again I can't see these on the diagram.
Kev
Super major rear lights wiring
Re: Super major rear lights wiring
Your side lights and rear lights feed from the centre single tail light/number plate plug so you have one single wire from the switch to the single lamp then two wires each to the side light and tail light from that. The earth is through the metalwork. The rear light is fed from the side light.
