Hi I was wondering what lift arms would also fit a super major.
Are the dexta or 1000 series lift arms the same? or were the cross shafts different?
The reason I ask is I am after some lift arms with the extra hole for a PUH
Thanks in advance
Will
Lift arm compatibility
1962 Super major
1960 4wd dexta (home built)
1963 Super dexta
1963 Super dexta
Re: Lift arm compatibility
None of the lift arms are compatible with a Super.
Roadless63
I'm afraid you are after the holy grail, I am not aware of anything else that will fit. I have seen folk asking up to £300 - £400 for a pair of these. Trouble is the splines wear so many s/h ones are next to u/s. One of mine had bad splines, I got hold of a decent normal super lift arm and was going to get the centers machined to re-spline to pick up hitch arm. Since then a guy on ebay has been listing some repro arms for £200/pair so I bit the bullet and bought a pair. They look good but haven't tried them yet.
Happy hunting!
Happy hunting!
I feared that may be the case
So my search will continue, if not maybe I could manufacture a pair by welding the extra lug on with dissimilar rods then drill it out,
Has anyone done this before???
1962 Super major
1963 Super dexta
1963 Super dexta
Hi There was somebody on here maybe middle of last year that was making his own pickup hitch top arm But can't remember who
He had some pictures of it to I think. Maybe try a search of the forum and see what comes up
super6954 wrote:Hi There was somebody on here maybe middle of last year that was making his own pickup hitch top arm But can't remember whoHe had some pictures of it to I think. Maybe try a search of the forum and see what comes up
Hi I just did a search for some of brians wisdom on another topic and found what you needed toowill c wrote:I feared that may be the case![]()
I assume you mean this one :
http://www.fordsontractorpages.nl/phpbb ... tch#p22863
I also found this one
http://www.fordsontractorpages.nl/phpbb ... hp?p=14716
Thanks for all your help
Will
Will
1962 Super major
1963 Super dexta
1963 Super dexta
Yes will that's the one I forgot about the other one i posted in that to at one point
so you got all the info now that you need so good luck with it and hopefully we can help you again sometime, all the info is here someplace you just have to find it or the guys that know about it if not in a topic already.
