nashby wrote:Hi all, so i have a new major with just the rear linkage and the trailer hydraulics, i have fitted a rear forklift on the link arms, all i need is flow and return for the forklift as it has its own control valve, i have made an a frame to stop the link arms lifting so I can use the forklift, it all works but the tractor hydraulics click out when i try to lift anything heavy, i was hoping to move packs of bricks around but it wont even lift 1 tonne, the oil in the back end is a bit milky but what should the hydraulics lift? any advice greatly appreciated
I have a fork on the back of my power major and it works alright, but I am using a auxillary hydraulics that bolt on to the front of the normal spool valve.
I have the weight of the fork and the weight of the lift on the normal hydraulics, and agree without a ROPS frame it is scary, but I have two lifts the normal hydraulic and the centre mast type ram lift.
This is all double acting hydraulics, both lift and tilt. Biggest problem I have had is breaking levelling boxes.
My fork will lift just about anything however the front wheels end up about 4 foot in the air and it is impossible to steer.
Does your fork have a single lift ram with chains relaying the lift?
My normal hydraulics don't hold much weight either however with the auxillary hydraulics the blow off pressure must be very high and this doesn't give up.
I would have thought you would have tapped into the main hydraulic line under your seat, to work your remote control valve you need to somehow bypass the normal spool as they do blow off at relatively low pressures for fork lift work, you may have to do some work on the unloader valves which are covered somewhere on this site too.
The remote spools also have blow off valves often also.
I also have another fork I will be setting up soon and it only has a single acting lift ram but it still uses chains to lift the forks, this fork I will have to set up differently and the top tilt ram is mounted higher, the bottom TPL arms only hold it in position and do no lifting becaues these are braced so the weight in not carried on the usual lift arms.
I also suggest you tighten the ring of bolts that hold both axle tubes onto the central diff housings as they come loose and leak, a word of warning the axle tubes are cast iron and will break under some high load conditions, though I have never seen it myself.
Mike
