made a start on the petrol/kero major , here are a few pics and questions
022 by shergar3, on Flickr
auxiliary gear chewed up
013 by shergar3, on Flickr
pump gear
018 by shergar3, on Flickr
crank gear a little chewed the rest of the timing gears look ok ,what would cause this damage and could i replace with a gear from a diesel ?
012 by shergar3, on Flickr
015 by shergar3, on Flickr
oil pump gears pitted , i have a spare from a later major with the integrated pressure relief could i use the internal gears?
051 by shergar3, on Flickr
someone has been here before , a repair to the governor , also it has only four balls my manual says it should have five?
053 by shergar3, on Flickr
one ball badly pitted
039 by shergar3, on Flickr
also no timing mark on bottom pulley
002 by shergar3, on Flickr
under the rocker cover it's a bit of a mess what would cause this? but she has been stood best part of thirty years.
024 by shergar3, on Flickr
distributor cap does not fit right could it be the wrong one?
any advice would be gratefully received
thanks Wayne
