Non-Minimec Pump Control Rod
Posted: Fri May 04, 2012 12:10 am
by whirly
I'm having problems starting my FPM. I have fuel to the bleed on the injector pump but the lift pump keeps pressure and there is no fuel to the injectors. #9 in the troubleshooting guide in FO-21 indicates that the "Pump control rod" could be "stuck in closed position". I've never been inside the injector pump so:
1) Is this the same control rod that is in the diaphragm housing?
2) Is it connected in any way to the stop control lever? Just seems they are on the same plane in the pump.
3) What is the best way to "unstick" it :?:
Re: Non-Minimec Pump Control Rod
Posted: Fri May 04, 2012 2:32 am
by whirly
I think I found the answer:
JC wrote:Remove the side cover. Make sure its very clean first, a little dirt inside can do a lot of damage. Lube the rack with ATF or penetrating oil and move it back and forth by hand until the governor spring can push it back by itself. Put the cover back on and try the vacuum test again.
Now the next question .... Can this be done on the engine or should I remove the pump first?
Posted: Fri May 04, 2012 4:07 am
by super6954
Yes it can be done on the tractor if access to the pump is not restricted by a loader frame or stuff like that so you can work on it comfortably :wink: . i have done quite a few :) Just make sure that the pump and surrounding area are really clean. If you are doing it outside try and pick a day when the wind is not blowing dust and grass/straw around as you don't want this stuff in the pump :wink: .
I hope this helps :)
Posted: Fri May 04, 2012 4:21 am
by whirly
Thanks Robert.
It is in the barn and I've cleaned off the entire area around the pump. I'll take a go at it tomorrow morning :beer:
Posted: Sat May 05, 2012 1:13 am
by whirly
That was it :!:
Ran the rack back and forth while drenching the ends with WD40; cleaned up the fuel stop end with ScotchBrite as much as I could and buttoned 'er up. Immediately got fuel to all the injectors and, after tightening up the injector pipes, he started right up.
Thanks Robert & JC
