Plough for Major
Posted: Sat May 19, 2012 7:14 pm
by 4040t
Hello,
I have just bought a plough for our Super Major. I believe it is a Ransomes
Could anyone tell me which model it is? as the identification plate is part missing/damaged
The points have YL62 cast into them. There are various casting numbers on different parts which seem mostly to start with "EP", though i'm not sure if they are relevant to the model number
I would like to know in case I need to get any parts in the future, the skim parts are missing for a start
Many thanks
By adriansimage at 2012-05-19
Re: Plough for Major
Posted: Sat May 19, 2012 8:20 pm
by henk
You have bought a Fordson Ransomes EP plough. I have just finished mine rebuilding. This one is in good shape and looks original. Mine was in a bad shape. I think it's a late model because the bar for the depth wheel is a bended one like the Ransomes, or it’s a replacement. Mine has a casted one. They were made at the Ford foundry, but later on Ford stop building them and Ransomes took over. The serie was then called FR implements. It’s replaced by the Ransomes model T56.
http://people.zeelandnet.nl/hmdetroije/ ... index.html
The last part is not written. Planning to test it in a few weeks.
Posted: Sat May 19, 2012 9:28 pm
by 4040t
Thank you very much Henk
A very infomative site you have there
Would you have an idea of what type of boards are fitted on mine?
Posted: Sun May 20, 2012 12:44 pm
by henk
I think you have YL body's. Mine are DM model. There are different type numbers for the plough. EP-J, EP-G and EP-C. The last letter has to do with the plough body's, but I don't know what it means.
Posted: Tue May 22, 2012 10:59 am
by tom lad
hi
i think , but might be wrong , you're bodies are yl 165 , designed for shallow ploughing , it should ( :wink: ) have it stamped on the back of the body / mouldboard .
Posted: Tue May 22, 2012 9:39 pm
by 4040t
I have had a look for any markings on the boards but nothing stands out
I have since found a website selling spares and they do look like they could be YL's of some description. It does have YL cast in the points so I presume this is related to the boards too
I don't know very much about ploughs and it's good to learn something new, thanks for your help
It's for my wife as it happens, she is just starting out in a bit of local "Fun" ploughing and having borrowed a plough last time and thoroughly enjoyed it, I thought we ought to get our own :D
