White Smoke
Posted: Mon Jun 11, 2012 2:03 am
I have a problem with my tractor and I was hoping that I could get some advice.
I have a Fordson Power Major with the Mark II engine and pneumatic governor. The tractor has not done any work over the past few years, it has only been started up about every six months or so and run for about 10 minutes.
A few weeks ago I used the tractor to spread some fertiliser, with a three point linkage spreader. I ran the tractor for about 4 hours and it went well. The following weekend I used the tractor for about another 4 hours spreading fertiliser. Once again the tractor ran very well. I ran the tractor on mid-throttle for the full 4 hours. The tractor didn't blow any smoke.
When I had finished the work and was going to put the tractor in the shed, I pushed the throttle lever up to the idle position. As I did this the tractor immediately started blowing clouds of whitish smoke and the engine seemed to be running a bit faster. The tractor did not respond to the throttle very much and blew smoke in all throttle positions. I then parked the tractor and left it.
The next weekend I started the tractor again. I started the tractor with the throttle in about the mid position. The tractor started straight away and ran well for about 5 minutes. I was just starting to think that everything was alright, but when I pushed the throttle lever to idle it started blowing lots of white smoke again. Since then the tractor blows smoke every time I start it. The tractor is still starting alright.
I have checked the air cleaner, air inlet and the butterfly valve in the inlet manifold. All of these are good. I tried advancing the timing on the injection pump but it didn't make any difference. I have run the tractor for about 20 minutes and it did not use any water out of the radiator.
I was hoping that someone may be able to give me some advice on what the problem might be. I have spoken to the local fuel injection company and they can recondition the injection pump for $2,000.00. They said that they were working on 3 Fordson pumps in there workshop at that time.
Before getting the pump repaired I just wanted to check if there might be some other problem that I should check first.
Thanks for any advice.
