Replacing Transmission Seals
Posted: Mon Feb 04, 2013 11:07 am
I am a newbie at this.
I have a "New Fordson Major Mark 1" November 1954. Tractor Serial Number is: 1318034
Quite a bit of oil is leaking from the rear axle seals. Also have oil leaking between the Gearbox and Rear End. The oil in the transmission is quite milky. it this common?
I am thinking of splitting the tractor, replacing the seals for the main shaft and PTO drive. Then do the Axle seals.
I am wondering if there is anything in particular that I should know before starting. Any particular tools that I need for replacing the seals?
Anything else I should be replacing while I have it in halves and the oil out..
Many thanks for any feedback. Andrew
