				Power Major Water Temp tube Routing
				Posted: Mon Sep 29, 2008 7:51 am
				by Dietmar
				How was the water temp bulp tube routed original?
Is it on the left or right side? Does it go outside the battery tray attachment frame.
Any hint would help.
best regards
Dietmar
				Posted: Mon Sep 29, 2008 5:55 pm
				Under the battery tray and along the left side of the engine with all the other wires in the same clips.
				Posted: Tue Sep 30, 2008 9:58 am
				by Mike Kuscher
				Interesting answer Brian.
On my Major, viewed from the drivers seat, the route is down the right hand side of the engine, through what appears to be original existing clips for it.
Mike
				Posted: Tue Sep 30, 2008 10:24 am
				by Grani
				This is perhaps off topic, but I was able to route the original tube between the pipes of the exhaust manifold all the way to the front of my 590 E engine. It looks nearly like a guitar string but it works.
				Posted: Tue Sep 30, 2008 10:44 am
				Power Majors and Super Majors used a different wiring route to Majors, Mike. Yours are in clips suspended from the bolts holding the tappet block cover, Power/Supers had a bracket near the starter then a bent tab on the side of the block near the dynamo.
