Removing injector copper washers from the head
MBeattie
Post by MBeattie »
Hi, I am sure someone has faced & resolved this problem before ? The next problem I have in rebuilding my cylinder head is that that the copper washers that seal the injectors at the bottom of the casting in the head are stuck at the bottom inside the head ? Any ideas how to get them out ?
Thanks, Mark.
Mjg1705
Re: Removing injector copper washers from the head
Post by Mjg1705 »
Hi - Ive just faced the same thing - the ones that were stuck I managed to get out with what they call an "oil seal pick" which is angled and managed to just break them away carefully - see if you can get something like a seal pick - may work.
Regards:mike
scoobyjim
Post by scoobyjim »
with a screwdriver slightly larger than the size of the hole, give it a knock into the hole. This should slacken the washer and bite into it to pull it out.
MBeattie
Post by MBeattie »
Thanks for the suggestions, manged to remove them with a screwdriver. Washers also came out when I removed the injectors, so 3 of the cylinders had 2 copper washers each ?, but will only have 1 per injector now when I put it back together :)
Thanks, Mark.
