Lift pump
Lift pump
Hi, im in the process of replacing the lift pump on my tractor, my question is, do you have to put the lever in at an angle or should it sit straight in the hole?
Re: Lift pump
look in the hole you will see the cam shaft. the arm should sit on top of the cam.
Re: Lift pump
It is a little easier to put in when the cam is in its lowest spot. You will feel spring pressure against the arm when you install it. This is normal. Dandy Dave!
