Hello,
i have a 1960 fordson major diesel , runs great..however,i am missing a part i cannot locate anywhere , there is no radiator cap , and there is no place to put a radiator cap , there are 2 hoses at top of radiator , 1 is not connected to anything , i assume its supposed to have some sort of fitting that accpts a radiator cap , i cant find this part anywhere... if anyone can help identify , sketch up , pictures..something to figure out what belongs here. I have run her alot with no cap,nno overheats or splilage....
ron in connecticut USA
info needed 1960 ford major radiator cap / hose / fitting
Ron in Connecticut
1960 ford major
1960 ford major
Meanderer
- Location: Elora Ontario, Canada (transplanted from Crookwell, NSW, Australia)
Welcome to the Forums ron,
I think this should show what you are missing!
The engine is not likely to run to it's designed efficiencies unless the cooling system is functioning as per design. You should be able to locate one from a "wrecker" as we call them in Aust. Others might call them "breakers".
regards,
Rick
regards,
Rick
Regards,
Rick
Regards,
Rick
TRY HERE Re: info needed major radiator cap
http://www.fordsontractorpages.nl/ubb/F ... 00055.html
Here is a pix of a wrecker yard in WI USA. They told me they have 7 Fordsons (Dexta-Major) broke down on the shelves, very little sheet metal left. Contact for what you need?
I bought some stuff from them and are quick to ship. Payment maybe made by Credit Card,
Contact info:
Craig
Wisconsin Tractor Parts
5764 Cnty Rd A
Black Creek, WI 54106
1-877-530-2010
craig@asapagparts.com
Web: asapagparts.com...
Contact info:
Craig
5764 Cnty Rd A
1-877-530-2010
ron wrote:Hello,
If you can't find an original anywhere, you might try cutting the filler neck out of an old (scrap) metal radiator ....should be able to find something in an auto junkyard that would clamp into the hose and you can get a working pressure cap for ....you would have to fabricate a mounting bracket also.
Probably wouldn't be very pretty, but might get you back working.
