Power Major Tractor seat
I have a late 1950's model Fordson Power Major Tractor. There seems to have been a design change around 1960 as to the seat configuration. Has someone got a part number and/or photo of the applicable tractor seat for Power Major tractors prior to 1960?
Re: Power Major Tractor seat
An exta comfort seat was available as an optional extra on the Power Major, cost was 8 pounds 10/- ($17.00)Aust in 1959.
Hi. In New Zealand I have Driven both major and power major with both types of seats as well a live drive major that my late father bought for me to drive when i was 15 years old.
cheers Les.
cheers Les.
Page 16 of the parts manual shows all of the seats available from Fordson and the part numbers. I would suspect one of the ones with the adjustable fore/aft bracket is what you want. My PM had the Delux less H.P.L. (whatever HPL is
'59 Power Major
Ancient Smurf
Ancient Smurf
Any chance you could email page 16 to me? simco@netconnect.com.auwhirly wrote:Page 16 of the parts manual shows all of the seats available from Fordson and the part numbers. I would suspect one of the ones with the adjustable fore/aft bracket is what you want. My PM had the Delux less H.P.L. (whatever HPL is)
Hydraulic Power Lift ie 3 point linkagewhirly wrote: (whatever HPL is)
"Classic Contracting"
International 784 4WD
& looking at another tractor!
Simco - Done
Kev - Thanks - I just wasn't thinking
'59 Power Major
Ancient Smurf
Ancient Smurf
Hi Simco, where are you at?
Pat
My Power Major has the unit on the lower right, my Supers have the unit in the middle.
This is on my Dads 58, I have never seen another and do not know what the spring loaded clip in the middle just below the top shaft does, I can only assume there are parts missing or it is some what home made.
I belive this is the standard unit.
Plane Jane industrial.
These Rest-O-Ride units were fairly common over here in the US. (Probably not a rest-O-Ride but I can't make out the tag, maybe Comfort Ride)
Pat
Last edited by BearCreek Majors on Wed Jun 19, 2013 7:14 pm, edited 1 time in total.
The seat on the 58 major is the same as the one on our 58 major in New Zealand. The spring held the front of the seat down. Our major was a live drive model with low ratio down high up.
Cheers Les.
Cheers Les.
Hi Les, could you take a picture of that, I apparently am missing something as there is nothing for it to attach to.
My dads Major has the live PTO as well, other than the wheels they are probably almost identical units.
Thanks.
Pat
Thanks.
Pat
Sorry we sold the major in 1969. Les.
The 58 seat is the same as I have on my 1960 Power Major. It is correct for that P.M. era. Dandy Dave!
Dave, can you get me a picture of what that spring loaded clip hooks to?
Pat
Pat
hi Pat,
There should be a steel flat strap welded accross the front of the side rails (approx 20mm x 3mm) and the sprind clip hooks on that which keeps the seat down.
Hope this helps, i cant get a photo to show you
Thanks Mark, I do believe you solved the mystery for me! I just went out and looked at the front of the mounting brackets and found the remains of some welds. It looks like I need to weld a piece on as you described and then flip the middle bracket around so the clip will then engage onto it.
Pat
Pat
Hi Pat,
Is this the photo you are looking for?
There could be a conflict with your hydraulic lines.
Is it a double acting remotecontrol?
Regards Matthias
With County, you can
1959 Power Major
1963 Super Major
1964 NP Super Major 4x4
1966 County 654
1959 Power Major
1963 Super Major
1966 County 654
Ahaaa, and I need to remove the shaft that is hitting the clip and put a pin in each side.
Thanks guys!
Pat
Thanks guys!
Pat
Yup. That is how a spare seat I puchased from a tractor breaker looks. My latch was also missing, but the spare seat will make it complete again. Dandy Dave!
Several pictues I took a while ago.
I have the same seat on my mk2 e1a if you undo the small clip the seat effectively pushes back meaning when you are getting on or off their is more room and it avoids getting mud on your seat
My Fordson Power Major has starting revving excessively once in use for 10-15 minutes and blowing excessive smoke. Suggestions?
Start a new thread. Posting a new topic in this one won't get you the attention you need.simco wrote:My Fordson Power Major has starting revving excessively once in use for 10-15 minutes and blowing excessive smoke. Suggestions?
'59 Power Major
Ancient Smurf
Ancient Smurf
