After running the tractor for a few minutes water started to seep from the rear between the head and block.
We stripped it back down again and the new gasket more or less fell to pieces as we did, so we put it down to a bad gasket.
We have now refitted with another gasket and this time water started to seep out as soon as the radiator was filled.
We stripped it out again, looked for any obvious problems, cleaned everything and tried again but still have the same problems.
We plan to take the head back to the machinist and ask them to check it over again but is there anything I should be looking for ???
Any advice appreciated.
Thanks,
