Looking for a favor JC, can you take a photo of how the front upright parts of the super 6 footplates mount onto the tractor please. (both sides), I am finally going to fit mine but think i am missing soething !!
cheers Sandy
Calling JC, super 6 picture wanted!
This is the front of right one. There's a lot of extra junk bolted to it, that I'll remove soon. I don't think that the bent piece of strap that's bracing it belongs there, but I'm not sure.
The front of the left one. It doesn't look like its been modified
This is the bar that goes across the tractor, taken from the right side.
The bar from the left side. I'll try to get another picture, tomorrow, of where it attaches.
I may need some pictures of yours, too. Does it have a swinging or fixed drawbar?
Hi Sandy
Here's a couple pictures of the cross bar mounting. I'm not much of a photographer, and its not an easy place to see into. If you can't tell anything from the pictures, here's how it mounts.
There's a small piece of flat strap that bolts to the same holes (on the steering box) as the back of the front fuel tank mounts. The cross bar is welded to that, at a small angle, so that the cross bar is at the same angle as the front of the foot plates.
In the second picture, you can see the end of the flat strap and one of the mounting bolts behind the tube for the temp. gauge. If you need more pictures or some measurements, let me know.
P.S. Here's a picture of my draw bar. Some parts have been changed, but I think some of it may be original. Does any of it look like yours?
Thanks.
JC
Thanks.
JC
