Serial/ID Numbers
Posted: Tue Sep 03, 2013 8:39 am
Morning people,
I have some ID numbers from two tractors, one of which I'm looking to buy. Can anyone help with dating, wether the codes tally, any information would be appreciated.
Here are the numbers.
Tractor 1.
Serial No ( under injector) 08C782555
Casting codes..(clutch linkage) N14X
Hydrolics (under seat) N14X
Front axle 2N5
Engine block, has no number, but has a raised ford emblem.
Reg 443DBD.
This tractor has round wings in blue.
Tractor 2
Serial No (under injector) S362707
Serial No( on fire wall) 1404018)
Casting codes (clutch linkage) L24Z
Hydrolics (under seat) H3V
Front axle 13L6
Engine block, has no number, but has en fo cast into block, also has this mark on cross member,by bottom left of radiator looking from engine.
Thanks. Pip.
Tractor 1.
Front axle 2N5
Reg 443DBD.
Tractor 2
Front axle 13L6
Thanks. Pip.
