Rear PTO Bearing help..?
Posted: Sun Oct 13, 2013 9:36 pm
by thestig246
not been on here for a while progress has been abit steady as of late due to work comitments, i had a spare this afternoon and im trying to change the bearing on the end of the pto shaft, but there is this sleeve on there :? im gueesing its a heat stunk job to get it on there. IS there an easy way to get the thing off so i can replace the bearing??
many thanks dan
Re: Rear PTO Bearing help..?
Posted: Sun Oct 13, 2013 11:39 pm
by Dandy Dave
Ahhh, Yeah. One of these always makes the job so much easier. :D Dandy Dave!
http://www.eautotools.com/HT0807-p/ht08 ... pingengine
Posted: Mon Oct 14, 2013 9:04 am
by thestig246
ahhh i will have to go and ask my friend nicely if i can borrow his :lol: im working outside and have very little in the way of workshop tools.. except a big hammer of course 8)
thanks dave.
Posted: Tue Oct 15, 2013 12:00 am
by Dandy Dave
Here's the one I'v been using. Dandy Dave!
Posted: Thu Nov 14, 2013 5:01 pm
by thestig246
thats a nice press there :) i went and bought a 20ton press and been pressing that collar but still cant get the bugger to move :x i had 10 tonnes of pressure of it and the bearing blew up and went everywhere! :shock:
So i could get the plates underneath proberly to press it, but ive put around 8-10 tons on that collar and she still wont budge! ??
any suggestions would be great :)
dan
Posted: Thu Nov 14, 2013 6:03 pm
by AdrianNPMajor
You could try applying some serious heat (eg oxy/propane) quickly to the collar and then try pressing again. If that doesn't work, you may have to cut the collar off and have a new one made. The original was probably heated and shrink-fitted onto the shaft. You'd have to do the same with the replacement.
Best
Adrian :thumbs:
Posted: Thu Nov 14, 2013 8:05 pm
by liam
I am doing the same job .Adrian is right ;it is shrunk on .Liam.
Posted: Fri Nov 15, 2013 6:44 pm
by thestig246
ok thankyou for your promt response :) i will get onto the case
all the best dan
