Front plate thread size.
Hello all. Can someone tell me the thread size of the four holes at the front of a 1957 major. The holes that straddle the hand start handle aperture. Thank you in anticipation of an answer cheers Martin Suffolk.
Daves rusty bits
Re: Front plate thread size.
I pretty sure they are 3/4" UNC. If your threads are as rusty as mine were run a tap through to check before buying bolts to be certain. Dave
