fordson major photo,s
Posted: Sat Jan 04, 2014 2:46 pm
by fordson993
i have some image of my fordson major so as promised Unfortunately, not all of them, I'm still part lost
we take of the eninge
broken cluch
i have cleaning the major gearbox and rear bridge
i fount this in the gear box, is this from the gearbox brake?
Re: fordson major photo,s
Posted: Sun Jan 05, 2014 3:14 pm
by Dandy Dave
Ouch. :shock: The crack in the clutch disk does not look good. That will need to be replaced. The metal in the gearbox is hard to say. Look at all the bearing cages to see if any are missing. Could also be pieces from the parking brake on a super. Looks fairly clean otherwise. Dandy Dave!
Posted: Sun Jan 05, 2014 7:02 pm
by henk
you made a handy and save tool to support the rear end. Pitty fot the clutch, can you fix this?
Posted: Mon Jan 06, 2014 9:44 am
by fordson993
I bought another cluch this is as good as new, I just need to have a center as for the clutch. and my engine that has been renovated last year.
Posted: Mon Jan 06, 2014 10:11 am
by AdrianNPMajor
If that's a Fomoco badge on the left side of your gearbox, looks like you have a New Super Major 63-64.
Best
Adrian :thumbs:
Posted: Tue Jan 07, 2014 6:06 pm
by AdrianNPMajor
Re the fragments you found in your gearbox, they look like a disintegrated wear plate from the transmission brake. The dowel in your photo, one of two, holds the interleaved stationary plates in position and it looks like it has got very hot. Highly likely that the brake has been left on at some point - a not uncommon occurrence. The photo below shows the two types of plate interleaved. New plates are available. As you've got the gearbox apart, it's worth fixing.
Best
Adrian :thumbs:
Posted: Tue Jan 07, 2014 6:13 pm
by AdrianNPMajor
Oops! Just looked at your photos again. You haven't got your gearbox apart! :oops: Still, where you are now, it's not a big job. Remove the primary gearbox and you're there. I'd recommend fixing it.
Best
Adrian :thumbs:
