Ebro 470 fordson super major
Posted: Sat Feb 15, 2014 6:20 pm
Hi my name is Scott, I live in Ontario Canada. Im working on a Ebro 470 Tractor. I believe the main gear box is a fordson super major gear box. The Ebro has a 2 clutch disk clutch, i need the pto clutch input shaft. Did the fordson super major with two disk clutch use the same pto input shaft in all there gear boxes? and can you still buy this part?
