Electrical device placement
Posted: Wed Mar 12, 2014 11:19 pm
Could anyone tell me where the voltage regulator and the solenoid mount? The battery box has a possible mounting spot for the solenoid which seems to place it in a verticle position. I know the regulator has to be close by the solinoid, but I see no mounting spot.
Another question is my tractor came with batteries tied together negative to negative, positive to positive. The book does not show it that way. Which is right I just had my starter and generator worked on and don't want to destroy them. I do understand that hooking the batteries up as above gives you 24 volts. Won't that be a little hot for my 12 volt starter? I plan on turning the headless engine over to distribute the oil. Maybe turn it over with one battery is the right way to go?
Kerry
Kerry
