What size is my Dowty Coupling?
drz400
Post by drz400 »
My Dowty Coupling Leaks and I am going to order a new one from Agriline but I am unsure which is the correct size.
Please could someone confirm for me. Thank You.
The overall diameter is just over 3/4" at the threaded section.
sorry for the shaky pictures it's blowing a gale out there!!!!!
atkiman
Re: What size is my Dowty Coupling?
Post by atkiman »
It will be 1/2 inch.
There are two types of Dowty coupling listed by Sparex. "MF" and "Exacta"
I fitted the male "MF" type to my Major, but there was a small leak when the McConnel digger was working, the inside of the female Dowty on the McConnel was stamped "Exacta" so I changed it to a "MF" type from Malpas. I don't know if it was just that the Exacta coupling was old and leaky, or if there is a small difference in sealing surfaces, but no more leaks now.
Maybe have a look at the female side you are going to use and see if it is stamped. Note the "MF" type didn't have anything stamped on it.
drz400
Post by drz400 »
Thanks I thought I better double check before getting one. I would of got the bigger one! my old one just leaks when you lift the 3 point arms up fully. Thanks again
neilarmo
Post by neilarmo »
How many do you want, a dozen in my shed!
peter2
Post by peter2 »
I reuse an old thread, because the heading says it all.
I think my coupling is different from the one above.
Here it is:
outer diameter is about 35mm,
inner (the part that is pressed inside is about 15mm
and the pipe behind is 13mm
Is this this the male part? Is this the 1/2" BSP version (the bigger one)? The thread was 13/inch, if I got it right.
I saw an adaptor at sparex (http://v2.ir.sparex.com/ItemDetails/Ite ... mber=13338, will it fit my coupling?
Is there any sealing between the couplings?
Peter
1963 Super Major
Stu_Fletch
Post by Stu_Fletch »
Mine and a mate of mine are both 1/2''
Stuart Fletcher aka Fletch - 27 - Leicestershire in the UK
1955 Diesel Major - Ford 2701E engine
Ford 4100 Bubble Cab
1996 New Holland 7740 SLDP 4wd & loader
county654
Post by county654 »
Hi Peter,
do you Need the "dowty" coupling?
If not, take it off and replace it with the female quick release typ. It is cheaper and there is one coupling less to cause problems.
Regards Matthias
With County, you can ;-)
1959 Power Major
1963 Super Major
1964 NP Super Major 4x4
1966 County 654
peter2
Post by peter2 »
Hi Matthias,
I want to leave it for originality reasons. If it starts making trouble it comes off.
Peter
1963 Super Major
