Sorry new to this. Have enjoyed my Super Major for a while but this year after a rest of a couple of months I proceeded to top my grass only to lose drive after only 50 metres with the engine bogging down and black smoke coming from under the fuel tank area. I was in low 3rd with PTO engaged. After leaving her to cool it is not possible to engage any forward gear but the clutch and reverse work ok as does the PTO.
Any ideas, what should I look at first. I love owning the tractor, am fairly competent with motorbikes but have little knowledge/experience with tractors other than routine servicing.
Any help much appreciated to get her going again!
Gearbox problems
Re: Gearbox problems
Hallo jord,
Sound pretty much like the problems I have
http://www.fordsontractorpages.nl/phpbb ... f=2&t=5893
Could it be the handbrake?
Regards Matthias
With County, you can
1959 Power Major
1963 Super Major
1964 NP Super Major 4x4
1966 County 654
1959 Power Major
1963 Super Major
1966 County 654
Yes thanks, does look like I stupidly didn't notice handbrake was slightly on. Now just plucking up the courage to split gearbox. How did you find it.
Yes, the only thing it could be is the handbrake friction welding itself together after being left on. The smoke would be the result of the oil being heated up. You'll have to split the tractor between engine and gearbox.
Splitting a tractor is a pretty crazy concept if you haven't done it before. With a car or a lorry you lift the bonnet or tilt the cab to reveal the engine and gearbox. Various access issues ensue. With a tractor, there are no real access issues - you part the ironwork and walk between them to have a look! This blew my mind a little when I first did it, especially after owning an old Citroen GSA, which was so badly designed in terms of maintenance that to change the spark plugs you virtually needed to remove one of the rear wheels! Not literally, but a hell of a lot of other stuff ended up on the floor!
You need to get your head around the basic operation of splitting the tractor - there is a wealth of experience on this site to draw on. Once you've got her apart, you're three-quarters of the way to solving your problem.
Best
Adrian
Best
Adrian
If Splitting is already 3/4 of the Job, it should not be rocket sience
If done it long time ago on our Dexta, the bigest tractor we used to own in the late 60ths on a 30ha farm , and later on a 7610 to do a job on the Dual power unit.
We will start in the next days, I will post some pics.....and probablly ask for further support
Regards Matthias
1959 Power Major
1963 Super Major
1966 County 654
1959 Power Major
1963 Super Major
1966 County 654
