Hello everyone,
I'm a new member Stuart Fletcher, but everybody calls me Fletch, i'm 26 from England and i thought i'd do a post about me and my tractor(s).
I bought my 1955 Diesel Major from a friend who had saved it from going to the scrap yard but he's got that many vintage projects on the go so decided it'd be a good opportunity for me to get into classic/vintage tractors. As i bought it the engine was completely seized and had been for many years we think, (rain through the valves), the sump was cracked and full of oil and mainly water, rocker cover rotted and so on. The tyres where had it the wings rotten, brakes seized, gear selector seized, bonnet hinge rotted, nose cone beyond any for of long lasting repair, and the list goes on as you can imagine.
My intentions were and still are to fit a newer 4 cylinder ford 2701e engine and eventually through use and finding faults cure them and eventually paint it back up to it's former glory close to a show tractor but obviously it wont be original. Me being of the younger generation decided that the characteristics and rattling noise of the injection pump coupling put me off the idea of rebuilding the engine so i sourced an engine locally and removed it from a welding rig, a fitted it.
Here's a few pics from how i bought it to now, please feel free to look through my album on photobucket: http://s1280.photobucket.com/user/Stu_F ... t=2&page=1
A video I took whilst out rolling one day - http://youtu.be/zuPh1LUAAJM
After a good bath with the steam cleaner
Loader removed - found rear r/h trumpet casting damaged
Obviously the most important thing at the time.... new front tyres, exhaust and a big box of bits from agriline!!
Old engine out new one to the left - There was speculation that the sump's would sawp - They wont!!!
Life with a loader on had taken it's toll on the trunion pin mounts on the tombstone
Modified track rod i fabricated from a John Deere 680 square baler pick up shaft.
Now for some reason i can't find any more of the photo's of the conversion and i'm sure i took plenty but over a matter of long nights after work and early mornings before work it made it's first journey out... 25 miles nearly faultlessly.... see following pics.
Gearbox oil leak from the bell housing. This core plug to the right of the input shaft where you can see clean oil running down had cocked over and wasn't sealing so i fitted a new one, i also drilled the breather on the gearbox that had bee i think soldered up although it looked as if it had never been drilled from new.
New clutch plate fitted as the original was contaminated and slipped.
Morning out on only one of the only frosty nights we had all winter as it was to wet otherwise to get down the fields
I stripped this down to shim the relief valve as it could only produce 800psi - set to 1950psi. unfortunately it still wont lift the 3f Ransomes reversible i want it to that we have on the farm so i've bought an assistor ram off i think a 7600 that i'm going to fabricate some brackets and that'll sort that out.
Day out rolling revealed leaking rear r/h trumpet as it joins the main transmission housing and leaking sump, and front crank seal.
Punctures repaired and new bonnet fitted.
This is my work van, I'm a service technician working mainly with Fendt, Challenger, and Cat, but also on Massey's and Valtra's
One of the/my dads farm tractors 1996 Ford New Holland 7740 SLDP
Ploughing with the plough i want to put on my major.
Hopefully that was enough but not too much for everyone... If anybody wants to know anything about any work I've done on it or the conversion, more pics etc i will be glad to share and help you anyway I can.
Fletch
Introducing Me and my Major. (Lots Of Pics)
Stuart Fletcher aka Fletch - 27 - Leicestershire in the UK
1955 Diesel Major - Ford 2701E engine
Ford 4100 Bubble Cab
1996 New Holland 7740 SLDP 4wd & loader
Re: Introducing Me and my Major. (Lots Of Pics)
Welcome to the Forum, Fletch; I suspect that your obvious experience in things agricultural will be an asset -- provided you are not just grandstanding, of course, but keep an eye on the various posts.
Isn't a 3f reversible a bit over the top, not in grunt, but in grip and forward motion, for a Major?
Hi Pavel.
No i'm definately not here to grandstand, I struggled with ideas and knowledge with my project and have read and used plenty of information off this site and wanted to offer anyone my experience, to give a bit back so to speak, I'd be glad to help anyone in anyway i could and i guess i'll need help too.... Everyday's a school day!!
It pulls my 3 furrow Ransomes TS59 well and that's set at 12'' just like the reversible.... I would have thought in in slippery conditions it would struggle without difflock and draft control but I'm not using it to work, but to have a bit of a play with i don't take it too seriously. I usually use a my ts59 with 2 furrows for match ploughing with the major and the New Holland with the reversible for matches as well. Yeah look out for some topics i'll put in here with a couple of things I need a pointer with.
Fletch
Fletch
Welcome Aboard Matey. Looks like you had your work cut out getting her this far. Dandy Dave!
Hi Fletch great work so far, how's the assistor ram going? I would love to attatch some to my major but am struggling for ideas on how to mount, I don't suppose you have any photos of hours yet?
Thanks loui
Thanks loui
Hi Fletch great work so far, how's the assistor ram going? I would love to attatch some to my major but am struggling for ideas on how to mount, I don't suppose you have any photos of yours yet?
Thanks loui
Thanks loui
I haven't yet either but I was going to use the bolts that secure the drawbar plates on the left hand side and then fit a longer pin onto the lift arm in the usual place. I haven't tried to lift the plough I want to since I have tweaked the hydraulic pressure to 2500psi which one of the service manuals advises when trying to lift heavier implements. A failed gearbox repair and house move have meant the major isn'the coming on as I would've liked and is taking up space in the workshop until I get some more time for it.
Let me know how you get on if you do. If you search 'fordson major assistor ram' on youtube you'll find a 6 cylinder modified major tedding some hay with a quick walk around. If you pause it in the right place you get a nice view of it.
An that's no problem, that's the hardest part trying to find time to get the majoirs finished!
Thanks I took a look at the video and see what you ment. I was thinking of trying to make a bracket off of the axles but his idea seems to work well!
I will post some pictures when I get to this point
Thanks again
Thanks again
Hello Fletch,
Enjoyable read, your post, and good photos to go with it!
Thanks for that.
Your old Major gives me heart, as I have one nearly as bad as your start pictures!
I too am not getting on with it as fast as I might. Buried in snow at present, and a shoulder ligament detached. (Just been told that I'll get to see specialist for a Consultation in 6 -8 Months!)
I think they filled the rear end on mine with linseed oil. No joke either. gear shift will hardly move, and valve chest had to be soaked for ages in petrol to get anything to move.
You are doing a grand job on yours. Do keep us updated won't you?
Lovely looking land as well, and nice to see the ploughing.
I'm looking for a Ransomes 3 furrow for mine, but since I'm now in Canada, they are Very thin on the ground.
All the best,
Richard.
Thanks for that.
All the best,
Richard.
