i'm restoring a 56 major it's missing all the rear lights, i have the old fender mounts for i believe the egg shaped lights also have to long metal mounts that run up inside the fenders, no light hardware left on them, however there are wires that used to run up there, so i'm assuming that there were other tail lights as well? is there a picture available so i can see if these are the correct tail light mounts?
thanx
huzy all i have is the mounts where the lights were, long metal mounts that were bolted to the inside of the fenders and ran up, i believe they had ford part numbers on them, i'll have to get a picture of them and see what you'all think?
