Hello Dave
Yes, I'm going to spruce her up a bit when I get the chance. All the things on your list, plus
wiring, rev counter, mud guards ........
Need to get the drawbar back on board too.
When I was ploughing, a split pin sheered on one of the clevis pins connecting the lift arms to the drop arms. End result: pin came halfway out of clevis and plough dropped, bending one jaw of the clevis. Bent it back into shape cold with the mother of all stilsons! To make sure it doesn't happen again, I'm going to get some longer clevis pins made. The originals are only longer enough to take a very thin split pin and with no room for a washer.
There are probably a few other jobs that you'll spot that need doing. Mind you, that's half the fun of owning these mean machines, isn't it?!
Any signs of cold weather with you yet? Still mild here.
Best, Adrian.
