Breather question
lwright
Breather question
Post by lwright »
I took off the breather stack and notice a liquid, must be water in the bottom. Is that suppose to be there?
What suppose to be inside the air canister? Any replaceable filters?
http://www.pbase.com/wrightsphoto/image/107097678
http://www.pbase.com/wrightsphoto/image/107097677
http://i.pbase.com/o2/50/470950/1/10709 ... G_0550.jpg
Thanks,
Larry
Grani
Post by Grani »
It is an oilbath aircleaner so there should be oil at the bottom. You can clean the whole filter unit with dieselfuel if you don´t have som other cleaning products and then fill the bowl to the mark with new engine oil.
lwright
Post by lwright »
Grani wrote:It is an oilbath aircleaner so there should be oil at the bottom. You can clean the whole filter unit with dieselfuel if you don´t have som other cleaning products and then fill the bowl to the mark with new engine oil.
Thanks so much for the info, I will take it off today and clean it up.
Thanks,
Larry
yelbike
Post by yelbike »
What type of oil goes in the breather?
JC
Post by JC »
Hi yelbike,
Welcome to the BB.
The air cleaner should use the same oil as the engine. If you use oil that's too heavy, it won't trap the dirt, if its too light, it could get pulled into the engine.
