Throttle linkages ??
paudie
Post by paudie »
Well guys I'm still at my FMD , I've got it wired with lights and dash etc all looks good ,new front cowel lights and lift arms to be fitted soon , my question is I have a hand throttle under the steering wheel and also the one on the side beneath the diesel tank which is the one that I'm currently using .its a1959 FMD and if I had to choose id like to use the throttle lever beneath the steering wheel,but here's the snag I can't find the linkages or diagrams that I need to connect my drop down linkage which comes from beneath the steering wheel to the bottom of the tank all the way to the butterfly air breather, is there a way I can combine both throttle Systems.
As usual here is the best place to get this info , any websites diagrams etc .
Paudie
