Belt Pulley Unit
Kav
Belt Pulley Unit
Hi all, Can anybody tell me if the Belt Pulley unit from an E27N will fit into a Super Major without Modifications? Thank you - Kav.
Re: Belt Pulley Unit
It won't fit.
The E27N pulley is a little different. The gear which transfers the power from the geabox intput shaft to the pulley is secured with a castellated nut on the E27N unit. With the introduction of the New Major a high/low box was added to the gearbox.
Therefore the casstelated nut crashes with the gears. From then on the pulley shaft was shorter and the gear secured with a circlip. Had the same issue about a year of ten ago. From memory the part no. for the shaft did not change, due to the backwards compatibility with the E27N shaft.
Rgds
It won't fit.
Rgds
Kav
Thanks Emiel - regards - Kav.
