Major Ignition
Jac Mac
Major Ignition
Post by Jac Mac »
Hi al,
l Iam new to the forum and have a question if any one can help.
I have a 1957 Major and need to short circuit the ignition,
there are 3 wires on the back of the ignition which do i short out to by pass the key?
Its a temp fix until she gets refurbed.
Thanks in advance Jack.
Grani
Post by Grani »
I think its the red and the yellow/red.
http://www.fordson.se/7_El_Verkstadsmanual_191-224.pdf
Jac Mac
Post by Jac Mac »
Thanks Grani,
I really appreaciate the promt response.If anyone can clarify the situation I would be grateful.
Jack
Jac Mac
Post by Jac Mac »
Can any one please clarify the situation with the above question.
Also is she neg or pos earth?
Thanks in advance Jack..
Grani
Post by Grani »
If You put together the red and the red with yellow stripe You get the same funktion as when you turn the key to on. Was this the thing You wanted? From the beguinning they have positive earth, but many owners change to negative earth when they change to alternators.
Jac Mac
Post by Jac Mac »
Grani thankyou once again, yes it is the information I require.
How will I know if she has been changed to alternator?
Thanks again Jack.
Grani
Post by Grani »
Jac Mac wrote:Grani thankyou once again, yes it is the information I require.
Thanks again Jack.
You have the original generator if it looks like nuber 3 on this picture
http://www.lh-osa.fi/nettikuvasto/major ... sivu33.jpg
And an alternator looks like this.
http://www.hitachi-hap-la.com/images/alternator.gif
Jac Mac
Post by Jac Mac »
Thanks grani I will take a look when its a bit warmer.
Jack
