E1A leaky seals
AlexE1A
E1A leaky seals
Post by AlexE1A »
Good morning all
Recently purchased a Fordson Major for jobs around our Holiday Park, there's a leak coming from this cylinder connected to the pto lever (dripping badly) would anyone mind letting me know what this is called or direct me to where I can purchase a new seal?
Thanks in advance :mrgreen:
Timeee
Re: E1A leaky seals
Post by Timeee »
Hello Alex
It is called the PTO Shifter Shaft Oil Seal, the Fordson Part No is E27N 7262-A. Dunlop Tractor Spares are pretty good for posting things on. They have it listed as Seal Major PTO Selector Shaft, their Part No ME150081. They are located near Ballymena, Co Antrim, N Ireland. Tel No 028 2565 2560.
Failing that, go into a place that sells bearings, chains etc with the old seal as a pattern. Make sure you have the diameter of the shaft and the internal diameter of the housing the seal sits in. Any decent bearing place should be able to sort you out with a replacement.
Don't forget to top up the gearbox oil level if it has been leaking for a long time.
Good luck
Tim E
AlexE1A
Re: E1A leaky seals
Post by AlexE1A »
Many thanks Tim, really appreciate it.
Spicklas
Re: E1A leaky seals
Post by Spicklas »
Also available via New Holland, part number 81717945. Costs about 30€.
Re: E1A leaky seals
30€ is ridiculous in my opinion. Try this first then. http://histoparts.com/nl/webshop/trekke ... major.html
Other suppliers will be in the same price range I suppose.
Rgds Emiel
