Engine Oil
AdrianNPMajor
Engine Oil
Post by AdrianNPMajor »
Just changed the engine oil.
Always used Morris 20w50, but this time I went for the Comma Classic 20w50.
Chery veap on Amazon! :D
Anybody have any views on these oil products?
Best, Adrian. :thumbs:
http://www.commaoil.com/productsguide/view/6/262
Re: Engine Oil
That is the one sold by Halfords.
I used it in the petrol tractors before I went onto Morris's which worked out cheaper for me. No problems as far as I found. Not tried it in the diesel engine though.
AdrianNPMajor
Re: Engine Oil
Thanks for the feedback, Brian.
According to the API rating (API SE CC) it's formulated for use in diesel engines also.
I must say, the Morris equivalent does seem to be the benchmark oil from what I read.
The price of the Comma is keener, though that would massive false economy if the oil is not up to the job. So far, so good .......!
CC
Service typical of certain naturally aspirated, turbocharged or supercharged diesel engines operated in moderate to severe-duty service, and certain heavy-duty gasoline engines. Oils designed for this service provide protection from bearing corrosion, rust, corrosion and from high to low temperature deposits in gasoline engines. They were introduced in 1961.
