Firstly, thanks for the wealth of knowledge generously shared on the forum. I used Brian's wiki on Henrietta's hydraulics to change the cylinder seal. Unlike Brian's experience, the supplier here in Australia was able to provide a seal off the shelf. I also made an adaptation to transfer oil from the hydraulics to the gearbox as required.
This tractor is badged Fordson Power Major and from the info on the forum I date it as 1960. Can anyone confirm this from the photo of the ID plate and tell me what each of the numbers on this plate mean?
There is no trace of any serial numbers on either of the two locations on the engine, but its casting code is E1ADKN6015 - E. Other casting codes I can read are
Gearbox D6D, Hydraulics (under seat) C22X, and two C30D.
It is gradually getting a long overdue cleanup.
