Australian serial numbers
Posted: Wed Jan 11, 2017 1:15 am
Hi all.
Can anyone please decode the Australian fordson serial numbers as stamped on the id plate. I figure the date is obvious but unsure how to understand the rest. My power major plate is as follows.
5 B M.1.60 2767 A529
It has a number stamped on below the fuel lift pump on the chassis rail which is V007004P
Below number 1 injector on the horizontal surface is stamped V007003P.
The engine number is stamped above starter motor and is 1524778 indicating a built date of September 1959.
Any information will be appreciated.
Thanks Ben
Thanks Ben
