Been a while since I posted to this form. So what I'm trying to do now is take an older fordson engine that originally had a single stage clutch and mate it to a super major chassis that is designed with the two-stage clutch. Can I put the two stage clutch and flywheel from the super major on the older engine and will all mate up and fit? Ideally I will be able to keep the two-stage clutch and utilize the older engine in the super major components.
Kind regards,
Dave W from California
Two stage clutch
Re: Two stage clutch
No problem it will all match straight up. You realise you will be dropping up to about 10 hp with a Major engine in a Super Major. Two stage clutch and flywheel will just go straight on the Major engine.
Thanks Brian! Glad to hear it. I realize I will loose some HP, but need to get my baby running.
Kind regards,
Kind regards,
