Front hubs
Posted: Mon Mar 27, 2017 7:56 pm
by woodcutter
Hi all I've got a diesel major with cast front wheels, if I want to change to steel wheels will the front hubs from a later major fit my axle/spindles or is there more to it than that? Cheers any advice appreciated
Re: Front hubs
Posted: Mon Mar 27, 2017 11:00 pm
by oehrick
I think so as ISTR using one after a shredding the tyre on a cast hub.
If no one else can confirm I'll measure the pair of tin wheel bores up when I go over to the tractor later in the week (I've a pair that remained when the Super departed for another life) The (bald) tyres are much wider than the ones on the cast hubs and are not nice without power steering.
Re: Front hubs
Posted: Mon Mar 27, 2017 11:12 pm
by woodcutter
Ok cheers my tyres are worn and I know of a pair of front hubs and wheels off a super major and I prefer the lighter steel wheels :D
Re: Front hubs
Posted: Mon Mar 27, 2017 11:22 pm
by liam
They are all the same ,Liam
Re: Front hubs
Posted: Tue Mar 28, 2017 4:32 pm
by woodcutter
Ok cheers do you use the same nut that holds wheel on to hold hub cheers
Re: Front hubs
Posted: Tue Mar 28, 2017 6:11 pm
by blackbob
woodcutter wrote: do you use the same nut that holds wheel on to hold hub cheers
Yes. I've done the swap too.
