Oil out the exhaust
Posted: Fri Apr 14, 2017 4:30 pm
As some of ye may know through my various posts ,I've totally rebuilt to the best of my abilities my FMD. I've worked my major at hay making, silage , and more recently when my old Leyland 255 decided to call it a day, the fordson was called In for yard scraping , The stock are back in the fields and I've bought an old barn find topper.
My issue at the moment is my 1959 totally rebuilt engine has started to blow black oil out the exhaust, would I be correct in assuming that it's a valve seal ??. If it is a valve seal how would I know which one . Ehaust or inlet ? And is it a easy job to do once I've the tappet shaft off ?
As ever i look forward to hearing your opinions and instructions
Paudie
Paudie
