Oil leaking from brake and clutch shaft
Posted: Tue May 30, 2017 10:01 pm
by FordsonTed
Hi there,
I've just been changing all my brakes on my 1959 power major While doing this I noticed I have oil leaking out of both the brake side of the shaft and the clutch side. It is coming from the hole the shaft comes out of both sides. It's definitely hydraulic oil. I'm guessing there is some sort of seal on the shaft itself. Is it a special type of seal if so where can I buy them?
Thanks for your help,
Ted
Re: Oil leaking from brake and clutch shaft
Posted: Tue May 30, 2017 11:04 pm
by FordsonTed
All sorted now found the seals!
