Live drive clutch issue
Hi all , i have a major live drive that was having issues with the clutch slipping, so I've pulled it apart to find yes it is slipping and needs new plates.But also the retaining cover is cracked in about 3 places. It is the type with 6 release forks. Was wondering can this part be replaced or is it a case of looking for another clutch assembly ?
Re: Live drive clutch issue
Replacement clutch unfortunately ,common problem with the dual clutch .I had the same problem ,ended up buying reconditioned clutch and release bearing from Dunlop Tractor Parts . Liam.
