Super major brake shaft
Posted: Thu Oct 05, 2017 5:53 pm
by woodcutter
Hi all I was going to replace seal behind brakes on super major and now found that the bearing is worn out how do I remove shaft, I've got brake housing off will the shaft just pull out or have I got to remove top and work from inside cheers any info appreciated
Re: Super major brake shaft
Posted: Thu Oct 05, 2017 10:28 pm
by mathias1
the shafts can be removed without removing the top. If you can have one side out, you can hammer the other one out using a long metal tube or something.
Posted: Fri Oct 06, 2017 1:03 am
Just pull it, they come out easily usually or take out the ring of bolts that hold it to the axle housing and take the whole lot out. Nothing will fall off if you do one side at a time.
Posted: Fri Oct 06, 2017 9:06 am
by woodcutter
Ok cheers I will have a go later, the bearing has had it the cage has completely gone, so hopefully I can purchase new bearings, I haven't took the diff lock side off yet but I'm guessing both sides will be the same
Posted: Fri Oct 06, 2017 10:26 am
by woodcutter
I've just popped out and tried pulling shaft out but won't budge so I've tried pulling whole lot out and it will come out about 10mil and stop and I've put levers behind and I've tried threading bolts in threaded holes to push it off but it's not budging any ideas or should I try other side and if that comes out hit through with a metal rod cheers kev
Posted: Fri Oct 06, 2017 3:56 pm
by woodcutter
Well I've had a good go at it and I can't get either side to come out, I'm thinking of welding a bolt on end of shaft and rig up a puller and see if that works
Posted: Fri Oct 06, 2017 5:55 pm
by mathias1
Try breaking the bad bearing?
Posted: Fri Oct 06, 2017 6:14 pm
by woodcutter
I did get it out but I had to weld a bolt on end and wind it out the other one tapped out quite easily then the left hand one with the bad bearing teeth are pretty chipped up, the diff lock side bearing isn't so bad but needs changing teeth are good so I need a new shaft for left hand side and two bearing plus seals, least the brakes looked good
