Identification of Fordson major diesel engine
Posted: Tue Feb 27, 2018 3:57 pm
by dromonedog
In the process of an engine overhaul and unable to verify engine series as the serial number is not stamped on RHS of block
Anyone able to help
Re: Identification of Fordson major diesel engine
Posted: Tue Feb 27, 2018 6:27 pm
by mathias1
maybe on LHS near the starter?
Could it be an early major?
Posted: Wed Feb 28, 2018 11:20 am
by shepp
Hello there
1) If this engine is in a tractor is there a number stamped on the bell housing
flange immediately behind the starter motor on the left side of the engine?
If so what is it?
2) Looking at the cylinder head from the left side are the ports for the inlet
and exhaust manifolds in line with each other or are the inlet ports
(and hence the inlet manifold) higher than the exhaust ports and exhaust
manifold?
3) Assuming this is an engine with a vacuum governed injection pump, looking
at the cover plate on the injection pump is it fixed with 4 bolts or 8 bolts?
Is the number cast on the cover plate SPE 4A 70S or SPE 4A 75S ??
